Hi everyone, I wanted to share my recent journey into automating my home using calendar events in Home Assistant. It’s been an exciting learning experience, and I hope my story can inspire others to dive into this feature as well.A few weeks ago, I decided to streamline my daily routines by integrating my calendar with Home Assistant. The goal was to have certain devices, like my lights and thermostat, adjust automatically based on my schedule. I started by exploring the calendar.get_events service, which allows you to fetch events from a specified calendar. This seemed perfect for my needs.I began by setting up a template to pull events from my calendar. The initial setup was straightforward—I configured the service call to fetch events for the next 14 days. However, I quickly encountered a challenge. While the events were being retrieved, they weren’t populating into my sensor as expected. The sensor remained ‘unavailable,’ and I couldn’t figure out why.After some research and debugging, I realized the issue was with how the response variable was being handled. The logs indicated that the variable wasn’t being properly recognized, which meant the sensor couldn’t access the event data. This was a bit frustrating, but it also became a learning opportunity. I spent time reviewing the documentation and experimenting with different configurations.Eventually, I found the solution by adjusting how the response variable was structured and referenced in my template. Once everything was correctly set up, the sensor started reflecting the calendar events accurately. It was a rewarding moment to see everything working smoothly.Now, I’ve set up automations where my lights dim and the thermostat adjusts based on my calendar events. For instance, if I have a meeting, the lights in my workspace automatically dim to create a focused environment. This level of automation has made my daily life more convenient and efficient.I’d love to hear from others who have implemented similar automations or have tips for optimizing calendar-based triggers in Home Assistant. What creative ways have you used calendar events to enhance your smart home setup?
