Exploring DC Power Measurement with Shelly UNI Plus
Hey everyone, I’ve been experimenting with DC power measurement using the Shelly UNI Plus, and I thought I’d share my journey and findings with you! :rocket:
For those who aren’t familiar, DC power measurement involves capturing both voltage and current to calculate power (P = V × I). While the Shelly UNI Plus doesn’t natively support this out of the box, its customizable inputs for voltage and pulses make it a great candidate for some DIY magic. :test_tube:
Here’s what I did:
  1. Hardware Setup: I used a HA4009 Hall-effect current sensor, which can handle DC currents up to 50A. This sensor converts current into a voltage signal, which I then scaled to fit the Shelly’s ADC range using a simple resistor network. The sensor requires a symmetric power supply, which I provided using a 3W DC/DC converter.
  2. Voltage Measurement: To measure voltage, I connected a voltage divider directly to one of the Shelly’s ADC inputs. This allowed me to monitor the voltage across a load in real time.
  3. Current Measurement: For current, I used a U/f converter module based on the LM331 chip. This converts the current sensor’s output voltage into a frequency signal, which the Shelly can then measure using its pulse input. While this setup works well for varying currents, it does have a minor limitation: it can’t measure zero volts accurately due to the nature of frequency-based measurements. However, this trade-off is acceptable for my use case.
  4. Software Integration: The final piece of the puzzle is a custom script that multiplies the measured voltage and current values to calculate power. I plan to publish this script soon, so stay tuned! :man::computer:
Challenges and Learnings:
  • The biggest hurdle was ensuring accurate scaling of the sensor outputs to fit within the Shelly’s measurement range. Too high or too low, and the readings become unreliable.
  • I also noticed that the Shelly’s web interface doesn’t update in real time, which means I have to manually refresh the page after making changes. Hopefully, this can be improved in future firmware updates.
Why This Matters:
Accurate DC power measurement is crucial for optimizing energy usage, especially in solar setups or high-current applications. By leveraging the Shelly UNI Plus, I’ve been able to create a cost-effective solution that integrates seamlessly with my smart home ecosystem. :star2:
If anyone has questions or suggestions, or if you’ve tried something similar, I’d love to hear from you! Let’s continue to push the boundaries of what these devices can do. :blush:
Cheers,
