Exploring Google Home Mini's TTS Queue Issue
Hey everyone, I came across an interesting issue with my Google Home Mini and wanted to share my experience in case others are facing the same problem. Google Home Mini has been a great addition to my smart home setup, but recently I noticed something odd happening with the Text-to-Speech (TTS) feature. The device started queuing up multiple TTS commands and wouldn’t play them back in real-time. Instead, it would just sit there with all these MP3 files waiting to be played, which was pretty frustrating!
I tried a few things to troubleshoot the issue. First, I thought maybe it was a connectivity problem, so I checked my Wi-Fi connection. Everything seemed fine there. Then, I decided to manually trigger a TTS command through the device’s configuration settings. To my surprise, when I did that, all the queued MP3 files started playing one after another. It was like the device had been holding onto these commands without any way to clear them out!
This happened a couple of times, and I noticed it usually occurred after I had multiple routines or automations triggering TTS messages in quick succession. I started wondering if there was a limit to how many TTS commands the device could handle at once. Maybe it gets overwhelmed if too many are sent too quickly. I also tried restarting the device, but that didn’t seem to make a difference.
After some research, I found that others have experienced similar issues. It seems like the Google Home Mini’s TTS queue can sometimes get stuck, especially when dealing with multiple commands in a short period. A temporary workaround I discovered is manually triggering a TTS command through the device settings, which forces the queue to process all the pending messages. It’s not a perfect solution, but it helps in the meantime.
I’m curious if anyone else has encountered this and if there are better ways to handle it. Maybe there’s a setting or a feature I haven’t discovered yet that can manage the TTS queue more effectively. I’d love to hear your thoughts and experiences!
Cheers,
