Exploring Google TTS Integration in Home Assistant
Hey everyone! I’ve been diving into the world of smart home automation lately, and I wanted to share my experience with integrating Google Text-to-Speech (TTS) in Home Assistant. It’s been a fascinating journey, and I hope to get some insights from the community as well.
So, here’s the setup: I’ve been using Home Assistant for a while now, and I recently decided to add some voice notifications to my setup. The idea was to have Google’s TTS read out sensor values, like the outside temperature, whenever I trigger a specific action. Pretty cool, right?
I started by setting up a simple script. The goal was to have Google read out the current temperature from my outside sensor. The script looked something like this:
yaml
service: tts.google_say
target:
entity_id: media_player.home_mini
data:
message: “Outside is {{states(‘sensor.outside_temperature’) | round}} degrees”
At first, everything worked perfectly. Google’s voice would chime in and announce the temperature whenever I triggered the script. It was a great way to stay updated without having to check the dashboard manually.
But then, out of the blue, Google decided to change things up. Instead of reading out the sensor values, it started reading the actual script code. Words like “open curly bracket sensor dot states” started coming through, which was pretty confusing. I was like, “Wait, what just happened?”
I checked the script again, and everything seemed fine. The template section in Home Assistant worked perfectly, so why was this happening? I decided to reach out to the community to see if anyone else had encountered this issue.
The responses I got were really helpful. Some suggested checking the permissions for the Google TTS service, while others recommended reviewing the script syntax. One user even mentioned that sometimes Google’s API can be a bit finicky with certain characters or formatting.
After some troubleshooting, I realized that the issue might not be with the script itself but with how the message was being parsed. I started experimenting with different ways to format the message, ensuring that all the curly brackets and syntax were correctly placed.
Finally, I found a solution! By wrapping the sensor value in a proper template and ensuring that the message was correctly formatted, Google’s TTS went back to reading the temperature values as intended. It was a bit of a rollercoaster, but it taught me the importance of double-checking syntax and parsing in scripts.
This experience has made me even more confident in my ability to troubleshoot and customize my Home Assistant setup. It’s also reminded me of the incredible value of this community—without the support and advice from others, I might still be scratching my head wondering what went wrong.
So, if anyone else is having issues with TTS or script parsing, don’t hesitate to reach out. We’re all here to learn and grow together!
Happy automating, everyone! :rocket:
