Hello everyone! I hope you’re all having a great day. I wanted to share my recent experiences with configuring MQTT on my IHOST SONOFF setup and integrating it with my new Honeywell Lyric Thermostat. It’s been quite an adventure, and I thought I’d document my journey here in case it helps anyone else facing similar challenges.
Starting with MQTT, I was initially thrilled when it worked seamlessly until an update disrupted everything. I tried reverting to my old configuration, but nothing seemed to stick. After some research, I discovered that adjusting the listener port and ensuring proper volume mappings were crucial. I also found that using a different MQTT broker, like Mosquitto, made a significant difference in stability. It’s amazing how a few tweaks can bring everything back online!
Now, onto the Honeywell Lyric Thermostat. While it’s been a reliable addition to my smart home, I encountered an issue with the front buttons malfunctioning. After some back-and-forth with Honeywell support, they suggested that my C-wire voltage might be too high. This was a bit concerning, as I didn’t want to risk damaging the thermostat further. I decided to look into alternative options, such as the Ecobee, which I’ve heard has a more robust design. However, I’m still hopeful that adjusting the voltage or using a voltage regulator could resolve the issue without needing to replace the thermostat entirely.
In the meantime, I’ve been experimenting with different configurations and scripts to optimize my setup. For instance, I’ve been using a YAML file to manage my ESP32C6 devices, which has been working wonders in HA supervised mode. However, when I tried running the same code on my Windows 10 CLI, it threw an error related to lambda functions. It’s a bit puzzling, especially since I’m not a professional coder. I’d appreciate any insights or suggestions on how to resolve this discrepancy!
On a more positive note, I’ve been absolutely thrilled with the real-time status updates from my Plex server using MQTT and Tautulli. It’s such a neat way to keep track of what’s playing without any lag. I’ve even set up some automations to adjust the lighting based on whether a movie is paused or playing. It’s these little wins that make the whole smart home journey so rewarding!
I’d love to hear from anyone who has tackled similar challenges or has tips for improving MQTT configurations and thermostat integrations. Whether it’s troubleshooting connectivity issues, optimizing scripts, or finding the perfect smart home setup, let’s keep the conversation flowing!
Happy tinkering, everyone! ![]()
