Hey everyone, I’ve been diving into the world of MQTT and Hassio lately, and I wanted to share my experiences and ask for some advice. I recently switched from Home Assistant to Hassio, and while the transition has been smooth overall, I’ve encountered a few bumps along the way, particularly with MQTT connectivity.
First, I’d like to talk about the setup. I successfully installed the built-in MQTT broker in Hassio and managed to connect it locally. It’s been great to see everything working seamlessly on my local network. However, the real challenge came when I tried to connect my remote devices. Despite ensuring that all configurations were correctly set up, none of my remote devices seemed to connect. It was frustrating because they were already inaccessible, and I wasn’t sure where to start troubleshooting.
I decided to take a closer look at the MQTT configuration files. I noticed that my devices didn’t have any username or password set up, which might have been part of the issue. I started by adding credentials to the MQTT broker and then updating the device configurations accordingly. It was a bit of a learning curve, but I managed to get everything set up properly.
Another thing I wanted to share is how I integrated MQTT with my existing setup. I have a mix of sensors and switches, and I’ve been using MQTT to control them. For example, I set up a flood light switch using MQTT, and it’s been working perfectly. Here’s a snippet of the configuration I used:
yaml
- platform: mqtt
name: “Flood Light Switch”
state_topic: “switch/boys/floods”
command_topic: “switch/boys/floods”
payload_on: “ON”
payload_off: “OFF”
state_on: “ON”
state_off: “OFF”
optimistic: false
retain: true
This setup allows me to control the flood light directly from my MQTT broker, and it’s been a reliable solution. I also set up a sensor for the landing temperature, which gives me real-time updates on the temperature in my home.
One thing I’m still curious about is how to optimize my MQTT setup further. I’ve heard about the benefits of using retain messages and QoS levels, but I’m not entirely sure how to implement them effectively. If anyone has tips or best practices for MQTT configuration in Hassio, I’d love to hear them!
Overall, my experience with MQTT in Hassio has been positive, and I’m excited to continue exploring its capabilities. It’s been a great way to integrate my smart devices and create a more connected home environment. Thanks for reading, and I look forward to hearing your thoughts and experiences!
