Exploring OpenHAB Automation with JSR223/Javascript
Hey everyone, I’m diving into the world of OpenHAB automation and I’m curious about something that might be a bit tricky. I’ve been trying to figure out if it’s possible to trigger a rule when an item updates, even if its state doesn’t change. From what I’ve read on the forums, it seems like this might not be straightforward, but I’m hopeful that there’s a solution out there.
I’ve tried several triggers like UpdatedEventTrigger, ChangedEventTrigger, and ItemStateUpdateTrigger, but none of them seem to work unless there’s an actual state change. I even tested it with a single item instead of a group, but the result was the same. It’s a bit frustrating because I want to automate certain actions based on updates alone, not just changes.
Has anyone had success with this? Maybe there’s a specific trigger or configuration I’m missing. I’d love to hear your experiences and any tips you might have. Let’s see if we can crack this together!
Cheers,
