Recently, I’ve been diving into the world of OpenHAB, trying to get everything set up just right. It’s been an exciting journey, but not without its bumps along the way. One issue that’s been particularly puzzling is the management interface not showing up properly after logging in. The screen just stays blank, which is pretty frustrating, especially after putting in all that effort to configure everything. I tried reinstalling Docker and even copying over the openHAB folders, but the problem persisted. It feels like there might be an issue with the JSON storage files, but I’m not entirely sure where to start debugging. If anyone has any insights or tips, I’d be super grateful!
On another note, I’ve been exploring the functionality of my Aqara H1 double rocker switch. It’s supposed to have 12 different trigger functions, but I’ve only been able to access 5 of them. That’s a bit disappointing, especially since I was hoping to fully utilize all the features. I tried deleting and re-adding the device, but that didn’t help either. It’s like the other triggers just disappeared into thin air. Has anyone else encountered this issue, or know of a workaround? I’m really keen to get all those functions working as intended.
Lastly, I came across a post about someone’s Wyze Cam Pan randomly stopping after an update. They mentioned encountering error code 90 and the device going offline. I can relate to that frustration because my Wyze Cam Pan also had an update recently, and while it didn’t go offline, it stopped recording and detecting motion. It’s unnerving to have such a reliable device suddenly act up. I’m considering resetting it to factory settings, but I’m not sure if that will solve the problem. If anyone has any advice on how to troubleshoot or fix this, I’d appreciate it!
Overall, it’s been a mix of triumphs and challenges. The community support has been invaluable, and I’m hopeful that with some more research and perhaps a bit of trial and error, I can get everything up and running smoothly again. Happy tinkering everyone!
