Exploring Power Options for Wyze Cameras
I’ve been really impressed with the Wyze cameras I’ve been using around my home. They’re affordable and offer great features, but I’ve been running into a bit of a snag when it comes to powering them. The standard setup involves using a micro USB cable connected to a brick adapter, which works fine, but I’ve been trying to figure out a way to make the setup a bit cleaner—hiding the wires and all that.
I came across a post where someone mentioned splicing into the USB cable and running it through the wall to wire it into the electric system behind the wall. That got me thinking—would that be feasible? I’m not exactly an electrician, but I’m pretty handy, so I figured I’d give it a shot.
I started by carefully splicing the USB cable, making sure to insulate the connections properly. Then, I fished the cable through the wall, which was a bit of a challenge, but I managed to get it into place. Once it was in, I wired it into the electric system, taking every precaution to ensure safety. I was nervous about doing this, but after some research and careful planning, it turned out to be a success! The camera is now powered seamlessly, and the setup looks much neater.
This experience has made me realize how much potential there is for customizing these devices to fit your specific needs. It’s not just about the technology itself, but also about how you can adapt it to work perfectly in your environment. I’m really happy with how it turned out and would recommend giving it a try if you’re looking to hide your camera’s wiring. Just be sure to do your research and prioritize safety! :rocket:
