I’ve been diving into the world of smart home automation with OpenHAB and the Amazon Echo, and it’s been an exciting journey! However, I’ve hit a bit of a snag with my morning routine automation. Let me share my experience and see if anyone has some insights or tips to help me troubleshoot.
So, the goal is simple: every morning, I want my Echo to start playing my favorite radio station at a specific time. It works perfectly some days, but other days, it just doesn’t budge. The error log points to a ‘Bad Request’ when trying to validate the command. Here’s the rule I’ve set up:
configuration: {} triggers: - id: “1” configuration: itemName: dtMorningAlarmStart timeOnly: true type: timer.DateTimeTrigger conditions: actions: - inputs: {} id: “2” configuration: type: application/javascript script: >- if (items.getItem(‘stTypeOfDay’).state == ‘Wochentag’){ items.Echo_Show_Schlafzimmer_Musik_Sprachbefehl.sendCommand(‘Spiele SWR3’); console.info(“Play SWR3”); } else { console.info(“Not an Arbeitstag”); } type: script.ScriptAction
The frustration comes in when the system is unreliable. An alarm clock that doesn’t consistently work is more of a hindrance than a help! I’ve tried tweaking the rule, checking the Echo’s connectivity, and even resetting the binding, but nothing seems to consistently resolve the issue.
On a positive note, I’ve found the OpenHAB community incredibly supportive, and I’m hopeful that with some guidance, I can get this automation running smoothly. If anyone has encountered similar issues or has tips for ensuring reliable command execution, I’d be thrilled to hear from you!
In the meantime, I’m exploring alternative methods, like using different wake-up commands or integrating additional sensors to trigger the radio. It’s all part of the learning process, and I’m grateful for the opportunity to connect with others who share my passion for smart home innovation.
Cheers to all the tinkerers out there—let’s keep the creativity flowing!
