I recently came across the Aeotec Smart Switch 6 and its built-in RGB LED ring, which immediately caught my interest. The idea of using the LEDs to indicate various statuses, such as electricity costs throughout the day, seemed innovative and practical. However, as I started diving into the configuration, I encountered a few hurdles that I’m eager to overcome.
First, I discovered that the current zwave device database doesn’t include parameters 83 and 84, which are essential for controlling the LED color and brightness. This oversight means that defining items for these parameters results in errors in the logs. I’m curious if anyone has successfully added these parameters to the device database or if there’s a workaround to bypass this limitation.
Another challenge I faced is converting the HSB color values to the numeric data format that the zwave binding expects. I understand that the brightness parameter is a single byte, which should work seamlessly with a Dimmer item. However, the color parameter requires three bytes for Red, Green, and Blue, which adds complexity. I’m wondering if there’s a way to handle multi-byte parameters through items or if a custom rule could facilitate this conversion.
I’m also pondering whether it’s possible to create a script or rule that converts HSB values into the required format and writes them to the parameters. If successful, this setup could not only enhance my current project but also serve as a valuable resource for others looking to utilize the RGB LED functionality of the Aeotec Smart Switch 6.
I’m eager to hear from anyone who has tackled similar issues or has insights into resolving these challenges. Your experiences and advice could be instrumental in helping me achieve this project’s goals. Let’s continue to explore and innovate together in the smart home community!
