Exploring RGBW2 Flashing Issues and Possible Solutions
Hello fellow smart home enthusiasts! I’ve been diving into the world of RGBW2 lighting controllers and have encountered an intriguing issue that I’m eager to discuss and hopefully solve. If you’ve ever worked with RGBW2 devices, you might have noticed a peculiar behavior when dimming or adjusting colors at lower brightness levels. The lights tend to flash and shift colors unexpectedly, which can be quite distracting. I’ve tested this across multiple devices and firmware versions, including the latest 1.10.0, and the problem persists. It’s fascinating to see such a consistent issue across different setups, and I’m curious if others have noticed this or found a workaround. If you have any insights or solutions, I’d be thrilled to hear them! Let’s explore this together and see if we can shed some light on the matter. :rocket::sparkles:
