I recently had the opportunity to work with the Schneider Charge EV charger, and I wanted to share my experience and insights with the community. For those who might be considering integrating this charger into their smart home setup, here’s what I discovered.
First, the Schneider Charge model supports the OCPP 1.6 protocol, which is a great feature for those looking to integrate their EV charger into a broader smart home ecosystem. I was particularly interested in using this charger with my SpaceLynk device, specifically the LSS100200 or LSS100100 models. After some research, I found that compatibility is indeed possible, but it requires careful setup.
One of the challenges I encountered was understanding how to read information from the charger using ModBus IP. I reached out to the manufacturer and other community members for guidance, and it turns out that with the right configuration, it’s entirely feasible. I was able to set up a connection and start monitoring key metrics like charging status, energy consumption, and fault codes.
Another aspect I explored was whether it’s possible to use the charger without relying on the MontaCharge app. For those who prefer a more streamlined setup, the answer is yes! By leveraging the OCPP protocol and integrating it with your smart home hub, you can control the charger directly through your existing smart home interface. This means no need for an additional app, which simplifies the user experience.
I also considered the possibility of using alternative apps or custom scripts for more advanced control. While this is technically possible, it does require some technical expertise. For most users, sticking with the built-in OCPP support and integrating it into their smart home system should suffice.
In terms of troubleshooting, I found that the logs provided by the charger were invaluable. They allowed me to identify and resolve issues quickly, such as incorrect IP configurations or communication errors. I recommend keeping a close eye on these logs, especially during the initial setup phase.
Overall, my experience with the Schneider Charge EV charger has been positive. It’s a robust device with excellent integration capabilities, especially for those who are comfortable with smart home protocols and a bit of DIY setup. If you’re in the market for an EV charger and value flexibility and compatibility, I’d highly recommend considering the Schneider Charge model.
I’d love to hear from others who have experience with this charger or similar setups. What challenges have you faced? What tips or tricks can you share? Let’s continue the conversation below!
