Exploring Smart Home Automation and Sensor Solutions
As I dive deeper into the world of smart home automation, I’ve encountered a few interesting challenges and solutions that I’d like to share with the community. From tweaking automations to ensure seamless operation to exploring innovative ways to integrate various devices, it’s been a fascinating journey.
One area that has particularly caught my attention is the optimization of sensor data and automation triggers. For instance, I recently encountered an issue where an automation to trigger a scene wasn’t working as expected when activated by another automation. The root cause turned out to be the formatting of the entity_id string—manually triggered scenes used a simple string, while automation-triggered scenes wrapped the entity ID in an array. To resolve this, I had to create two separate automations, one for manual triggers and another for automated ones. While this workaround solved the immediate problem, I’m curious if there’s a more elegant solution or syntax that could unify these triggers into a single automation.
Another intriguing project I’ve been working on involves detecting constant water flow for extended periods while away from home. My initial attempt using a simple condition to check for water flow greater than zero resulted in false alarms due to appliances like the ice maker, washing machine, and dishwasher. To address this, I’ve been exploring ways to implement a condition that triggers only if the water flow remains consistently above a certain threshold for a defined period. This approach would help differentiate between brief, normal usage and potential leaks or prolonged usage.
On a more creative note, I’ve also been experimenting with integrating Node-RED into my smart home setup. By combining Blue Iris camera integration with VorlonCD AI tools and DeepStack for motion detection, I’ve been able to create a robust system that sends notifications with snapshots when motion is detected. This setup not only enhances security but also provides peace of mind, especially when I’m away from home.
I’d love to hear from others who have tackled similar challenges or have innovative solutions to share. Whether it’s refining automation logic, optimizing sensor data, or integrating new tools into your smart home ecosystem, the collective wisdom of this community is invaluable. Let’s continue to explore, experiment, and innovate together!
Cheers to all the fellow enthusiasts out there, and here’s to many more exciting projects and discoveries ahead!
