As I delve deeper into the world of smart home automation, I find myself constantly amazed by the possibilities that technology offers. Recently, I embarked on a project using the ESP32 microcontroller to create a custom sensor setup for my garden. The goal was to monitor soil conditions and automate watering, but the journey was filled with both challenges and triumphs.
One of the key components of my setup was integrating multiple MiFlora sensors to track temperature, moisture, illuminance, and conductivity. Initially, I encountered some hurdles with the ESP32’s ability to reliably connect to my Wi-Fi network after deep sleep. After some research and tweaking, I discovered that adjusting the Wi-Fi output power and implementing a more robust reconnection routine significantly improved the system’s reliability.
The configuration process was quite involved, but I documented each step meticulously. I used ESPHome for the firmware setup, which allowed me to define global variables and automate deep sleep cycles effectively. Here’s a snippet of my configuration that others might find useful:
yaml
esp32:
variant: ESP32C3
board: esp32-c3-devkitm-1
framework:
type: esp-idf
version: recommended
deep_sleep:
sleep_duration: 30s
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
output_power: 10
This setup ensures that my sensors enter a low-power state after collecting data, extending battery life significantly. I also implemented a script to check if all sensors have published their data before triggering deep sleep, which adds an extra layer of reliability.
One thing I learned is the importance of thorough testing. I initially faced issues with MQTT connectivity after deep sleep, but by adding delays and ensuring the Wi-Fi module had enough time to reconnect, I was able to stabilize the system. It’s a reminder that even small adjustments can make a big difference in IoT projects.
For anyone looking to embark on a similar project, I recommend starting with a clear plan and keeping detailed notes. The community support available through forums and documentation is invaluable, and I’ve found that sharing my experiences helps others while reinforcing my own understanding.
In the future, I plan to expand this setup by adding more sensors and integrating it with my home automation system. The possibilities are endless, and I’m excited to see how far I can push the boundaries of what’s possible with ESP32 and smart home technology.
