Hello everyone, I wanted to share my experience with setting up location and presence detection in my smart home using the OwnTracks app. This has been a game-changer for automating routines based on my whereabouts, and I thought it might be helpful to walk through my journey and some tips I’ve picked up along the way.
I started by understanding the basics of how OwnTracks works. It allows you to define geofences—essentially virtual boundaries around locations like your home, workplace, or even a favorite coffee shop. When you enter or exit these geofences, you can trigger actions in your smart home system. For example, turning on lights as you approach your home or adjusting the thermostat when you leave for work.
One of the first things I learned was the importance of accuracy settings. I initially had my geofences set with a very tight radius, which led to inconsistent triggers. After some research, I adjusted the minimum accuracy to around 150 meters, which helped ensure more reliable detections. This tweak made a significant difference in how smoothly my automations worked.
I also explored both HTTPS and MQTT communication methods. While HTTPS was easier to set up initially, I found MQTT to be more efficient and energy-friendly in the long run. Setting up an MQTT broker was a bit of a learning curve, but it gave me the flexibility to integrate other devices and services beyond just my smart home setup.
One challenge I faced was ensuring that the app was consistently communicating with my Homey. I had to generate new tokens a few times and adjust some settings in the configuration editor to disable HTTP authentication, which wasn’t necessary for my setup. This process taught me the value of checking logs and documentation when troubleshooting.
After getting everything set up, I started creating rules based on my daily routines. For instance, when I leave my home geofence in the morning, my coffee maker starts brewing, and my HVAC system adjusts to save energy. When I approach my workplace, my phone switches to silent mode and my desk lights turn on. These automations have made my life significantly more convenient.
I’d love to hear how others are using location and presence detection in their smart homes. What creative automations have you implemented? Have you encountered any unique challenges or found innovative solutions? Let’s share our experiences and continue learning from one another!
Happy automating! ![]()
