As I delve deeper into the world of smart home automation, I’ve come across a variety of interesting topics and challenges that others might find useful or intriguing. Here’s a glimpse into some of the questions, experiences, and solutions I’ve encountered recently:
1. Lorawan vs Z-Wave for Outdoor Monitoring
I’ve been researching the best IoT transport methods for monitoring my boats in a boathouse. While Z-Wave offers a wide range of compatible sensors, Lorawan’s long-range capabilities seem ideal for outdoor applications. Has anyone successfully integrated OpenHAB with Lorawan? I’d love to hear about your experiences or any tips for setting this up!
2. Zigbee Network Recreation in OpenHAB
I noticed a new option in OpenHAB version .109 that allows manually recreating the Zigbee network or doing it automatically upon reboot. I’m curious about when this feature would be most beneficial. For instance, should I enable it if I’m frequently adding or removing devices? Any guidance would be appreciated!
3. Button Status in OpenHAB GUI
One of my early challenges with OpenHAB was getting the button status to display correctly. After some experimentation, I switched from a toggle switch to a button switch, but the highlight effect still persists. I’d love to know if there’s a way to eliminate this highlight so the button simply shows “On” or “Off” without any additional indicators.
4. Car Detection Sensors
I’m looking for reliable sensors to detect cars in my garage or driveway. My current setup with MyQ garage door sensors doesn’t provide vehicle status updates. Any recommendations for sensors that integrate well with smart home systems like OpenHAB or Smartthings?
5. Smart Deadbolt Combo
As a newcomer to smart home automation, I’m exploring options for a smart deadbolt that can unlock both the deadbolt and lever handle simultaneously. Does anyone know of a combination deadbolt and handle set that works seamlessly with smart home systems? I’m particularly interested in hearing about successful installations or any potential issues to watch out for.
6. Migrating to C8 Hub
Upgrading to a new C8 hub from C7 has been an interesting process. I encountered some challenges with the migration, especially since my active hub doesn’t have Hub Protect. I had to manually migrate data and ensure a proper backup. If anyone has tips or tricks for a smoother transition, I’d be grateful!
7. Samsung SmartThings Mesh Router
I’m considering a mesh Wi-Fi solution for better coverage in my home. I’d love to hear if anyone has experience with Samsung SmartThings mesh routers compared to Google’s offerings. Are there any standout features or potential drawbacks to be aware of?
8. Fibaro Dimmer and Philips LED Compatibility
I’ve been experimenting with the Fibaro Dimmer 2 and Philips 5W-GU10-Warmglow LED lights. While the idea of dimming to warmer tones is appealing, I’ve run into issues where the lights blink instead of smoothly dimming. Has anyone found a solution or workaround for this? Tech specs or manual settings adjustments might be the key here.
9. OpenHAB Event Loggingverbosity
After migrating to OpenHAB 4, I noticed an increase in verbose logging, particularly for battery level updates that don’t reflect actual changes. Is there a way to filter or reduce these log entries while still capturing meaningful events? I’d love to streamline my logs without losing important information.
10. Smartthings and Arlo Integration
I’ve successfully integrated my Arlo cameras with Smartthings for geofencing-based arming and disarming. However, I’d like to set up a routine where unlocking my smart lock disarms the alarm without triggering any notifications. Has anyone achieved something similar or have advice on how to approach this?
The journey of setting up and optimizing a smart home system is both rewarding and challenging. Each new device or integration brings its own set of questions and opportunities for learning. I’m grateful for communities like this one where I can share experiences and gain insights from others. If anyone has additional tips, solutions, or stories to share, I’d love to hear them!
Happy automating!
