I recently embarked on a project to create a wake-up light system using Yeelight color bulbs, and I must say, the journey has been both enlightening and rewarding. The goal was to simulate a sunrise effect, gradually transitioning from a warm red hue to a bright white light, all without the need for complex scripting or additional hardware. Here’s how I achieved it and what I learned along the way.
First, I discovered that Yeelight bulbs are incredibly versatile. They support a wide range of color temperatures and can be controlled through simple text commands. This made the project much more accessible than I initially thought. The key was understanding the Yeelight Inter-Operation Specification, which provided all the necessary details to craft the perfect command.
The command I settled on was:
markdown
.sendCommand(“set_scene [“cf”,7,1,“2000,1,16711680,1,180000,1,16711680,20,180000,1,16731392,40,180000,1,16738048,60,180000,1,16744704,80,180000,1,16754432,100,180000,2,3400,100”]”)
This command creates a smooth transition from dark red to bright white over 18 minutes, ensuring a gentle wake-up experience. Each parameter in the command was carefully chosen to control the duration, color, and brightness of each stage of the transition.
One of the most surprising aspects was how straightforward the setup was. I didn’t need to write any custom scripts or use additional devices. Everything was handled through the Yeelight app and OpenHAB’s automation capabilities. This simplicity is a testament to the robustness of Yeelight’s API and the flexibility of OpenHAB.
However, the journey wasn’t without its challenges. Initially, I struggled with understanding the parameters and how they interacted. But with some trial and error, and a bit of research, I was able to fine-tune the command to perfection. It’s a great example of how even complex automation tasks can be achieved with the right tools and a bit of patience.
In conclusion, this project has been a fantastic learning experience. It not only improved my morning routine but also deepened my understanding of smart lighting and automation. If you’re looking to create a similar setup, I highly recommend exploring Yeelight bulbs and OpenHAB’s capabilities. The results are truly transformative!
Happy automating! ![]()
