I’ve been diving into the world of smart lighting and Fibaro modules lately, and I wanted to share my experiences and some tips for anyone looking to integrate these devices into their smart home setup.
Setup and Initial Impressions
I recently added a Fibaro FGBS222 module to my SmartThings hub. The goal was to use one of its inputs to trigger a chime and turn on lights between sunset and sunrise. The driveway sensor is connected to a Security panel zone, providing a dry closure or active low output. The module is powered by the control panel’s 12VDC supply, which is a solid start.
Challenges Faced
However, I ran into an issue where the module’s contact status didn’t change when applying or removing a ground for an extended period. It only toggled when there was a quick ground. This was unexpected, as I was hoping for a more consistent response.
Solutions and Workarounds
After some research and experimentation, I found that using a quick ground pulse was the most reliable way to trigger the module’s state change. While it’s not the ideal solution, it works for now. I’m still looking into whether there’s a configuration or firmware update that could improve this behavior.
Automation and Integration
For those interested in automating similar setups, here’s a quick tip: use the module’s state changes to trigger automations in SmartThings. You can set up routines that activate a chime and adjust lighting based on the time of day. This setup is perfect for creating a welcoming environment when someone arrives home or ensuring safety during late hours.
Community and Support
I’d like to extend a big thank you to the Fibaro and SmartThings communities for their resources and support. If anyone has additional insights or solutions for optimizing the FGBS222 module’s performance, I’d love to hear from you! Let’s continue to explore and share our experiences to make our smart homes even smarter.
Happy integrating! ![]()
