As a homeowner deeply interested in leveraging smart lighting to enhance my daily routines, I’ve been exploring various scenarios that integrate motion sensors, input selectors, and automated schedules. My goal is to create a seamless and intuitive lighting experience that adapts to different times of the day and user preferences.
One of the most exciting aspects of this journey has been experimenting with input_select for mode switching. By setting up modes like ‘Automatisch’, ‘Hell’, ‘Gedimmt’, and ‘Nachtlicht’, I can easily transition between lighting scenes without manually adjusting each light. This setup has proven particularly useful in areas like the hallway, where lighting needs vary depending on time of day and activity.
However, I’ve encountered a challenge in dynamically applying these modes based on time-of-day conditions. While I’ve successfully implemented a template sensor to auto-switch modes during different hours, integrating this into my automation logic has been tricky. Specifically, I’m looking for a way to reference the state of this sensor within my scene-triggering logic without causing conflicts or delays.
To address this, I’ve been experimenting with data_template in my automations. The idea is to use conditional statements that check both the input_select state and the template sensor’s output, then trigger the appropriate scene. While this approach works for static selections, the dynamic reference to the template sensor’s state has introduced some unexpected behavior, leading to delays or incorrect scene activations.
I’d love to hear from the community on best practices for integrating dynamic mode switching with scene automation. Have others successfully combined input_select with time-based conditions? What strategies have worked for ensuring smooth transitions without performance hiccups?
In the meantime, I’ve found that manually testing each condition in the developer tools provides valuable insights. It’s a bit time-consuming, but it helps identify where the logic might be breaking down. I’m also considering whether adjusting the polling interval of my template sensor could help synchronize the automation better.
Overall, while there are hurdles to overcome, the potential for creating a highly adaptive and user-friendly lighting system is incredibly motivating. I’m eager to continue refining this setup and share any breakthroughs with the community as I go.
