I’ve been diving into the world of smart lighting lately, and I must say, it’s been an exciting journey! As someone who loves tinkering with home automation, I’ve been experimenting with the Fibaro Dimmer 2 to create a seamless lighting setup. Here’s a bit about my experience and some tips I’ve picked up along the way.
The Setup
I have a couple of old knob-and-tube ceiling lights in my home, which are perfect candidates for smart lighting. Since these lights don’t have a neutral wire, I knew the Fibaro Dimmer 2 would be a great fit. I wanted to create a setup where I could control both the main light and a secondary outlet using a single dimmer. That’s where the idea of using a momentary dual switch came in.
The Challenge
I came across this momentary dual switch and was curious if I could wire it in a way that one switch controls the dimmer for the main light, while the other acts as a remote control for another Z-Wave outlet. The question was, how exactly do I wire this? Both leads into the S2 terminal? Or one into S2 and one into Sx? I reached out to the community for advice, and the response was overwhelmingly helpful!
The Solution
After some research and guidance from more experienced users, I discovered that wiring one lead into the S2 terminal and the other into Sx was the way to go. This setup allows the Fibaro Dimmer 2 to handle both the main dimming function and the remote control for the secondary outlet seamlessly. It was a bit of trial and error, but the satisfaction of seeing everything work together was worth it!
Tips for Others
If you’re looking to integrate a momentary switch into your Fibaro setup, here are a few tips I’d recommend:
- Plan Your Wiring: Take the time to map out your wiring connections before diving in. This helps avoid confusion and ensures everything is connected correctly.
- Test Each Component: Before finalizing your setup, test each component individually. This helps identify any issues early on.
- Leverage Community Knowledge: Don’t hesitate to reach out to forums or communities for advice. There’s a wealth of knowledge out there, and experienced users are often happy to help!
This project has been a fantastic learning experience. It’s amazing how a bit of creativity and the right tools can transform something as simple as lighting into a smart, integrated system. If you’re thinking about upgrading your lighting setup, I highly recommend exploring the Fibaro Dimmer 2 and similar solutions. The possibilities are endless, and the satisfaction of seeing your home come to life with smart features is truly rewarding!
Happy tinkering everyone! ![]()
