Exploring Smart Thermostat and TRV Integration for Oil Burner Systems
As someone who’s been diving into the world of smart home automation, I’ve been on a quest to upgrade my heating system. My current setup involves an old oil burner with a wired thermostat that’s not exactly cutting-edge. The thermostat is located in the kitchen, which doesn’t really need heating, and it tends to get thrown off when the oven is on. I’ve been researching how to replace this with a more modern solution that integrates smart thermostats and thermostatic radiator valves (TRVs).
My initial thought was to go for an all-in-one system like Tado, which supports two-wired heaters and TRVs. However, I’m hesitant about the cost and prefer local-driven solutions that can connect with my Home Assistant setup. I’ve been eyeing Zigbee or Thread compatible TRVs, such as those from Tuya, Sonoff, or Aqara, as they seem like a solid choice for reliable connectivity without relying on Wi-Fi.
Another option I came across is the Bosch Smart Home Controller II, which uses Zigbee-enabled TRVs. While this sounds promising, I’m still unclear on how it would integrate with my oil burner. I’d love to hear from anyone who’s successfully set up a similar system or has tips on connecting these devices seamlessly.
I also considered using standalone Zigbee TRVs for each radiator and controlling the oil burner with a smart switch. A Sonoff Mini Zigbee switch might do the trick, but I’m not entirely sure how to configure it for this purpose. I’ve heard about ESPHome relays, but that feels a bit too advanced for my current skill level.
If anyone has experience with integrating smart thermostats and TRVs for oil burners, especially in a Home Assistant environment, I’d be thrilled to hear your insights and recommendations! Let’s collaborate to find the best solution for this setup.
