Exploring SNMP Binding and Tuya Pool Heat Pump Integration
Hello everyone, I’m currently diving into the world of SNMP binding and Tuya devices, and I wanted to share my experiences and seek some advice from the community.
First, I’ve been working on setting up SNMP binding with OpenHAB. It’s been a bit of a learning curve, but I’m making progress. I’ve been using the ManageEngine MibBrowser Free Tool to test SNMP requests, and it’s been working perfectly. However, when I try to integrate this with OpenHAB 1.8.3 on my Raspberry Pi, I’m not getting any responses. I’ve checked the configuration files and even used tcpdump to monitor the traffic, and it seems like OpenHAB is sending requests but not receiving any responses. I suspect this might be related to how the SNMP port is configured, especially since netstat shows that OpenHAB is listening on an IPv6 port instead of IPv4. Does anyone have any insights or tips on how to resolve this?
On another note, I’ve recently acquired a Tuya-based Aquark pool heat pump, and I’m trying to integrate it with Home Assistant. The heat pump shows up in the Tuya app and Home Assistant, but I’m having trouble adjusting the temperature settings. I receive an error message stating that the service isn’t supported. I’ve read through some forums and it seems like others have encountered similar issues. I’m wondering if there’s a workaround or if I need to adjust the configuration in Home Assistant.
If anyone has successfully integrated a Tuya pool heat pump or has any troubleshooting tips for SNMP binding, I’d greatly appreciate your input. It’s been a bit frustrating, but I’m determined to get everything working smoothly. Thanks in advance for your help!
