I recently came across the FLeX-Switch and decided to give it a try, and I must say, it’s been a game-changer for my smart home setup! ![]()
The FLeX-Switch is designed to be more than just a traditional light switch. It offers a range of innovative features that make it incredibly versatile. For instance, it comes with a screw-on light plate that includes AC outlets and a built-in touch night light with adjustable color settings. This design allows for easy swapping between different plate modules, whether you prefer USB ports, AC outlets, or a mix of both. Plus, it’s compatible with Alexa, Google, and Siri, which means seamless integration with your existing smart home ecosystem.
I installed it in my living room, and it has completely transformed how I manage my lighting and electronics. The ability to switch between different plate modules depending on my needs is brilliant. For example, I can have a module with USB ports for charging my devices or one with AC outlets for powering small appliances. The built-in night light is also a huge plus—adjusting the color and brightness to match the ambiance of the room is so easy!
One of the best things about the FLeX-Switch is its hidden circuit design, which powers the built-in outlets. This not only keeps the setup clean but also ensures that everything runs smoothly without any visible wires. The fact that it’s Alexa, Google, and Siri compatible means I can control it hands-free, which adds a whole new level of convenience.
I would definitely recommend the FLeX-Switch to anyone looking to modernize their lighting setup. It’s not just a switch—it’s a smart, flexible solution that enhances your home’s functionality and aesthetics. If you’re considering upgrading your lighting controls, give the FLeX-Switch a try—you won’t be disappointed! ![]()
