I recently moved into a new home and decided to set up my Hubitat Elevation C7 hub in a way that would make it both functional and aesthetically pleasing. After some research, I stumbled upon a fantastic 3D-printed wall mount design on Thingiverse. The design was perfect for my setup, and it even included detailed instructions for modifying it to suit different mounting needs. I couldn’t resist giving it a try!
Here’s a quick rundown of my experience:
Design and Customization: The design I found was created by dgnuff and is available on Thingiverse. It uses small overhangs to securely hold the Hubitat in place, which I really liked. I decided to stick with the original design but made sure to measure everything carefully to ensure a perfect fit.
Printing the Mount: I used my new 3D printer to bring the design to life. The print came out smoothly, and the mounting holes aligned perfectly with my hub. The overhangs were a nice touch—they provided a snug fit without any additional hardware.
Installation: Mounting the Hubitat was straightforward. I drilled the holes in the wall, attached the mount, and secured the hub in place. It looks clean and professional, and I’m happy with how it turned out.
Benefits: Having the hub mounted on the wall freed up valuable space in my network closet. Plus, it makes accessing the hub’s controls much easier. I’m also pleased with how it blends seamlessly into my home’s decor.
If you’re looking for a neat way to mount your Hubitat Elevation C7, I highly recommend checking out this design. It’s a great example of how 3D printing can solve everyday problems in a creative and practical way!
Looking forward to hearing about your own DIY projects or setups—let’s share the love of creating and customizing our smart homes! ![]()
