Hello everyone, I wanted to share my recent experience with the latest firmware update for my smart home devices. I recently updated my system to the 2.7.11 ALPHA version, which I heard about in the community. The update process was straightforward, but I encountered a few unexpected issues that I thought I’d document here in case others run into similar problems.First off, the update seemed to go smoothly. I followed the instructions provided and registered at the指定链接 to access the update. The installation itself was quick, and I was excited to see the list of fixes mentioned in the release notes. However, after the update, I noticed that some of my custom automations were acting up. Specifically, a rule I had set up to adjust the lighting based on motion sensor input wasn’t triggering as expected.I spent a bit of time troubleshooting and realized that the issue was related to how the firmware handles regex matching in rules. I had set up a rule to match multiple items using a regex pattern, which worked perfectly before the update. After some research, I found that others in the community were also experiencing similar issues, and it seems like the update might have introduced some changes in how regex is processed.To resolve this, I decided to simplify my rule and avoid using regex for now. Instead, I hardcoded the item names in the rule, which worked like a charm. It’s a bit more manual, but it gets the job done until the regex functionality is sorted out.Another thing I noticed was that some of my sensors, particularly the contact sensors, weren’t updating their status as reliably as before. I tried the usual troubleshooting steps—unplugging the hub, waking up the sensors manually, and checking the logs—but nothing seemed to fix the issue. I reached out to the community for advice and was reassured that this is a known issue with the latest firmware. Thankfully, a software reset of the ESP module temporarily resolved the problem, although I’m keeping an eye on it in case it recurs.Despite these hiccups, I’m still impressed with how the firmware update has improved other aspects of my setup. The energy dashboard, for instance, is now more responsive and provides clearer insights into my consumption patterns. It’s just a matter of ironing out the kinks, which I’m confident will happen as the community continues to collaborate and share solutions.If anyone else has encountered similar issues or has tips for troubleshooting, I’d love to hear about it. Let’s keep the conversation going and help each other navigate these updates smoothly!
