Exploring the Meross MS600 Presence Sensor: A Comprehensive Review
Hi all, I recently had the opportunity to test the Meross MS600 presence sensor, and I wanted to share my experience with the community. This device has been quite the topic of discussion, so I thought I’d dive into its features, setup, and performance.
Setup and Initial Impressions
Setting up the MS600 was straightforward thanks to its Matter compatibility. However, I encountered a few hiccups during the initial configuration. The device dropped off the WiFi network a couple of times, which was a bit frustrating. After moving it closer to my router, it stabilized and hasn’t had any issues since. The setup process involved adding the sensor to the Meross app, which required creating an account. While I understand the need for an account, it would be great if Meross allowed for a more seamless setup without one.
Design and Features
The MS600 boasts a sleek design with a built-in stand that allows for angle adjustments. This is a nice touch, especially for those who want to optimize the sensor’s coverage. The device comes with a pet-proof shield, which is intended to block detection in the lower half of its range. However, I found this shield to be somewhat finicky—it didn’t stay in place without additional adhesive, which wasn’t included. While the concept is good, the execution needs some refinement.
Performance
Once configured, the MS600 performed admirably. It combines mmWave technology for presence detection with a PIR sensor for motion, offering a robust solution for monitoring activity in a room. The sensor can detect presence up to 6 meters and motion up to 12 meters, which is impressive for a device of its size. I appreciated the ability to adjust sensitivity levels and set absence cooldown periods, which adds a layer of customization to suit different environments.
Integration with Apple Home
One of the standout features of the MS600 is its compatibility with Apple Home. The presence and light sensors integrate seamlessly, allowing for easy automation setup. However, the PIR sensor isn’t directly accessible in Apple Home, which limits its functionality outside of the Meross app. This is a minor inconvenience, but it’s worth noting for those looking to fully leverage the device’s capabilities.
Conclusion
Overall, the Meross MS600 is a solid addition to the smart home ecosystem. It offers reliable presence detection and motion sensing, with a design that’s both functional and user-friendly. While there are a few areas where Meross could improve, such as the pet-proof shield and account requirements, the MS600 is a device worth considering for those in the market for a high-quality presence sensor. If you’re looking for a device that combines advanced sensing technology with ease of use, the MS600 is definitely worth a closer look.
Best regards,
