I recently came across the Octoprint Additional Buttons Helper Blueprint and decided to give it a try. This blueprint is a fantastic tool for anyone using the OctoPrint-HomeAssistant plugin, as it adds a suite of customizable buttons to streamline printer operations. Here’s my experience and some tips for getting the most out of it.The blueprint adds eight buttons, four of which you can customize with your own G-Code commands. This is incredibly useful for automating repetitive tasks or setting up quick-access commands for filament changes, bed leveling, and more. The safe shutdown and presentation mode functions are also a huge plus, making it easier to manage your printer from within Home Assistant.**Installation and Setup:**1. Requirements: Ensure you have the OctoPrint-MQTT and OctoPrint-HomeAssistant plugins installed on your OctoPrint server. You’ll also need an MQTT broker connected to your Home Assistant instance.2. Blueprint Configuration: The blueprint requires input fields for MQTT topics, device IDs, and sensor names. These can be found in your OctoPrint dashboard under the MQTT and Home Assistant Discovery tabs.3. Customization: After setting up the blueprint, restart your OctoPrint server to apply changes. This ensures all button entities are correctly registered.Tips for Use:- Auto-Shutdown Feature: The blueprint includes an auto-shutdown feature based on extruder temperature. I found it helpful to manually enable or disable this feature through the device settings in Home Assistant.- Troubleshooting: If changes aren’t reflecting, remember to restart OctoPrint. This step is crucial for any configuration updates.- Dashboard Integration: The author provided a sample Lovelace dashboard configuration, which I adapted to suit my setup. It’s a great way to visualize all your printer controls in one place.**Community Support:**The creator of this blueprint is very responsive and provides detailed documentation. If you run into issues, reaching out via the provided links is a great way to get assistance.Overall, this blueprint has significantly enhanced my 3D printing workflow by bringing more functionality into Home Assistant. Whether you’re a seasoned user or new to OctoPrint, this tool is definitely worth exploring!
