Hey everyone, I’ve been diving into the world of home automation lately, and I’ve come across an interesting challenge that I’d love to share with you. I’ve been using an AC thermostat alongside a radiator with a Tado valve in the same room, and I’ve been wondering why we can’t utilize the AC thermostat as a sensor for the heating radiator. It seems like such a straightforward solution—after all, the AC thermostat is already monitoring the room temperature, so why invest in an additional sensor? I’d love to hear your thoughts on this and whether anyone has successfully implemented a similar setup.
For those of you who are curious about integrating different devices, I recently stumbled upon a detailed guide on reading and writing global variables in Fibaro. It’s a fantastic resource for anyone looking to streamline their automation setup. The guide walks through setting up a REST command, creating an input number, and configuring sensors and automations to keep everything in sync. If you’re into tweaking your system for optimal performance, I highly recommend checking it out!
Another topic that’s been on my mind is the debate between iRule and OpenRemote for controlling AV devices and triggering scenes. I’ve been using Roomie on a Kindle Fire, but since it’s no longer supported, I’m on the hunt for a reliable alternative. iRule has caught my eye with its affordability and preset options, but I’m curious to know if the community has had positive experiences with it compared to OpenRemote. If anyone has insights or recommendations, I’d be grateful to hear them!
On a lighter note, I’ve also been experimenting with adaptive lighting and automations. It’s been a bit of a learning curve, but I’ve managed to create a system that dims the lights to 10% when there’s no motion in a room and brings them back up when movement is detected. However, I’ve noticed that the lights don’t always stay dimmed as intended—they tend to revert after a minute or so. I’ve tried tweaking the automation and even ticking the takeover box in adaptive lighting, but the issue persists. If anyone has encountered this and found a solution, I’d love to hear about it!
Lastly, I wanted to share a quick tip for anyone looking to enhance their home automation setup. If you’re considering migrating from an SD card to an SSD for your Raspberry Pi-based Home Assistant system, I’ve found some great resources on the best SSDs and enclosures for the job. The Samsung 870 QVO and the LEXAR SSD enclosure have been highly recommended for their reliability and performance, especially for 24/7 use. It’s been a game-changer for my system’s stability, and I’m thrilled with the results.
I’d love to hear your thoughts on these topics and any other experiences or tips you have to share. Let’s keep the conversation going and continue to learn from each other’s journeys in the world of smart home technology! ![]()
