As I dive into the world of Home Assistant, I’m excited to share my journey of setting up automations using my Nest thermostat as a trigger. While I’ve managed to integrate various devices, automating based on temperature changes has been a bit of a puzzle. I want to create a system where if the measured temperature drops below the set temperature, it turns on a Tuya switch, and turns it off once the temperature stabilizes.
Here’s what I’ve discovered so far: the Nest integration allows me to trigger automations based on measured temperature, but there’s no direct trigger for when the measured temperature crosses the set temperature threshold. This means I need to get creative. I think storing the set temperature as a variable might be the key. If I can store the set temperature in a variable, I could potentially use it as a threshold in another automation.
I’ve been exploring how to store variables in Home Assistant and how to reference them in automations. It’s a bit tricky, but I’m hopeful that with some research and experimentation, I can make this work. I’d love to hear from others who’ve tackled similar challenges or have tips for working with temperature-based automations.
On a lighter note, while I’m focused on getting this automation sorted, I’ve also been impressed by how seamless it is to integrate different brands and devices in Home Assistant. It’s amazing how a little bit of setup can lead to such powerful home automation. I can’t wait to see what other creative automations I can come up with next! ![]()
