I recently came across the Z-Wave JS integration for Home Assistant and decided to dive into it. After setting up my Z-Wave network, I stumbled upon the Z-Wave JS to MQTT addon and wondered how it could enhance my setup. I wanted to know if it’s necessary to install this addon during the initial configuration or if I can add it later without issues, especially since I already have several Z-Wave devices paired through Z-Wave JS.
After some research, I discovered that the Z-Wave JS to MQTT addon provides additional functionality, such as exposing Z-Wave devices to MQTT brokers, which could be incredibly useful for integrating with other systems or services. However, I was unsure if adding it post-installation would affect my existing devices or require any reconfiguration.
I decided to give it a try and installed the addon after my initial setup. To my delight, it worked seamlessly without any hiccups. My devices continued to function as before, and I gained the ability to publish device states to MQTT, opening up new possibilities for automation and integration.
If you’re exploring Z-Wave in Home Assistant, I highly recommend checking out the Z-Wave JS to MQTT addon. It’s a fantastic way to extend the capabilities of your Z-Wave network without compromising on stability or functionality. Happy automating! ![]()
