I’ve been diving into the world of Wyze cameras lately, and I must say, they’ve brought a lot of convenience to my home security setup. However, I’ve encountered a bit of a puzzle with my Wyze Cam Pan v3 and the Wyze Cam Floodlight. Let me walk you through my experience and what I’ve learned along the way.
So, here’s the setup: I have a Wyze Cam Floodlight mounted on my front porch, and I wanted to add the Wyze Cam Pan v3 to keep an eye on the sides of my house. The idea was to plug the Pan v3 into the USB port on the floodlight for a clean, wireless setup. But here’s where things got tricky—mounting them about 15 feet apart.
I started with a USB extension cable, thinking it would solve the distance issue. But unfortunately, that didn’t work out. The camera would go offline after a few minutes or even days, despite having strong Wi-Fi signal in the area. The camera itself still functioned—moving and tracking as it should—but the app would show it as offline. Frustrating, to say the least!
After some research, I found that power cables longer than 16 feet can cause issues with the Wyze Cam Pan v3. So, I decided to try a 15-foot cable. But this didn’t fix the problem; instead, it made things worse. The camera would reset repeatedly, with a clicking sound and the status light cycling from red to blue. It was like a never-ending loop of powering on and off.
This led me to wonder about the power specifications. The cable I had was a flat USB power adapter from Amazon, specifically designed for the Wyze Pan v3. But clearly, it wasn’t cutting it. I started to question if the power delivery was insufficient or if there was some incompatibility I wasn’t aware of.
I decided to take a step back and think about alternative solutions. Maybe the issue was with the USB port on the floodlight itself. Could it be providing inconsistent power? Or perhaps thePan v3 requires a more robust power source than what the floodlight’s USB port can offer?
In my search for answers, I came across a few forums where others had similar issues. It seems that the Pan v3 is quite sensitive to power fluctuations, especially over longer distances. Some suggested using a powered USB hub or even a dedicated power adapter for the camera. While I haven’t tried these solutions yet, they’ve given me some promising leads.
This whole experience has been a bit of a learning curve, but it’s also highlighted the importance of understanding power requirements when setting up smart devices. It’s easy to overlook such details, assuming that a simple cable would suffice. But as I’ve discovered, sometimes the devil is in the details.
I’m curious to hear if anyone else has encountered similar issues or has found a reliable workaround. Have you had success with longer USB cables or alternative power solutions for the Wyze Cam Pan v3? I’d love to hear your experiences and tips!
Stay curious and keep experimenting! ![]()
