After installing my Wyze thermostat a couple of days ago, I’ve been curious about how it interacts with my HVAC system. I previously used a Honeywell T6 thermostat, which kept the furnace on low most of the time, with minimal temperature swings. The Wyze, however, seems to have a different approach. The furnace often kicks to high speed, and the temperature swings are more noticeable. It appears the Wyze waits for the temperature to drop significantly before calling for heat, which results in the furnace going into high gear to compensate.
I’ve experimented with the thermostat’s sensitivity settings, adjusting the ‘Behavior’ range to both extremes, but it doesn’t seem to make a difference. The description of the Behavior setting is quite vague, making it unclear what it actually controls. It feels like Wyze is simplifying HVAC management with algorithms, which is great for those who don’t want to dive into technical details. However, for someone like me who enjoys tweaking settings, there’s a lack of deeper control options.
I wonder if others have encountered similar issues or found a workaround. Maybe there’s an ‘Advanced’ configuration option hidden somewhere, or perhaps a way to adjust sensitivity more precisely. It would be fantastic if Wyze could provide more transparency into these settings or offer advanced options for those who want to fine-tune their system.
Overall, while I appreciate the simplicity the Wyze thermostat offers, I’m eager to find a way to balance it with more precise control over my HVAC system. If anyone has insights or solutions, I’d love to hear them!
