As I continue to expand my smart home setup, I’ve been diving deep into the world of Zigbee, particularly the differences between Zigbee HA and LL. While both protocols share some common ground, understanding their nuances has been a bit of a puzzle. For instance, I’m curious about whether a single network can support both HA and LL devices seamlessly or if there are inherent limitations that might require separate setups. This exploration has led me to wonder about the native support for Hue bulbs within my ecosystem and whether the integration challenges stem from protocol incompatibility or simply unimplemented features.
In addition to protocol discussions, I’ve also been experimenting with automations, particularly with color bulbs and switches. The goal is to create a system where lights adjust based on motion but return to their previous state without unintended side effects. For example, setting the color temperature without turning the lights on or maintaining only the on/off state during transitions has been tricky. It’s a balance between simplicity and functionality, especially when scaling up to multiple bulbs.
Another area of interest has been the integration of ESPHome devices, particularly for monitoring and data logging. The idea of using an ESP32 module to track the water level in a rainwater tank and feed that data into InfluxDB without relying on Home Assistant is intriguing. It’s about finding the sweet spot between hardware simplicity and software efficiency.
Overall, the journey has been a mix of technical problem-solving and creative thinking. Whether it’s troubleshooting Zigbee compatibility, refining automation rules, or exploring alternative setups, each challenge presents an opportunity to learn and improve the smart home experience. I’d love to hear how others have approached similar projects and the solutions they’ve found along the way!
