I’ve been experimenting with extending the range of my Sonoff PIR-3RF motion sensors, and I wanted to share my findings and tips for anyone else tackling this challenge.
First, a bit of background: I’ve been using these sensors to monitor activity in my garden and around the house. While they work well in optimal conditions, I noticed that in certain areas, especially behind walls or in metal structures like my garden shed, the sensors weren’t reliably detecting motion. This was frustrating, as I rely on these sensors for security and automation purposes.
After some research, I came across a modification that involved improving the antenna. The default antenna on these devices is a serpentine track on the PCB, which is compact but not ideal for long-range communication. By adding an external antenna, I hoped to significantly boost the signal strength.
Here’s what I did:
Antenna Length Calculation: The ideal length for a quarter-wave antenna at 433.92MHz is approximately 156mm. I decided to use a solid-core insulated copper wire, which is relatively easy to handle and provides good performance.
Modifying the Sensor: I carefully opened up the PIR-3RF, removed the battery, and located the PCB. The antenna track was clearly visible, and I cut it just above the battery connector. This left a short section of the original track, to which I soldered the new wire antenna.
Housing Modifications: To keep everything neat, I drilled a small hole in the housing and threaded the antenna through it. This way, the antenna extends vertically from the sensor, which helps with signal propagation.
Testing and Results: After reassembling the sensor, I tested it in the problematic areas. The results were impressive! The sensor now reliably detects motion even in the garden shed, which was previously a dead zone.
Additional Tips:
- Orient both the transmitter and receiver antennas vertically for optimal performance.
- Use a superheterodyne receiver like the RXB6 instead of super-regenerative types, as they offer better noise filtering and range.
- Ensure the receiver is powered correctly and connected to the appropriate GPIO pins on your controller.
This modification has been a game-changer for my setup. It’s a simple DIY project that can make a big difference in the reliability of your sensors. If you’re experiencing range issues with your Sonoff PIR-3RF or similar devices, I highly recommend giving this antenna upgrade a try!
Happy tinkering! ![]()
