Extremely poor wifi with Aqara 5G Pro camera hub
I installed my new Aqara 5GPro Hub camera, wifi version. I am very happy with all of the features with one exception. The wifi signal at the installation site is very strong. The 5GHz signal is 200+Mbps. But the connection to the device is very poor. On the Aqara app it shows just one bar on the signal strength. The video feed repeatedly drops out and I get a message about poor connection strength. I have seen many other users with the same complaint. My mesh router is only about 12 feet away from the camera.
Is there are solution to this?
John
It should read, " the wifi signal is very WEAK".
  1. Check Power Supply: Ensure that the camera hub is plugged in and receiving power. Check for any power indicator lights to see if it is on.
  2. Restart the Camera Hub:Unplug the camera hub from the power source, wait for about 10 seconds, and then plug it back in. This can help reset the device.
  3. Check Internet Connection: Make sure that your internet connection is stable. Check if other devices connected to the same network are online.
  4. Reboot Your Router: Sometimes, restarting your router can resolve connectivity issues. Unplug it for about 30 seconds and then plug it back in.
  5. Check Network Status:If your camera hub is connected via Wi-Fi, ensure that it is within range of the Wi-Fi signal. If necessary, move it closer to the router.
  6. Look for Firmware Updates:Ensure that the firmware of your camera hub is up to date. Use the manufacturer’s app or website to check for updates.
  7. Inspect Cables and Connections:Examine any cables connected to the camera hub for damage or loose connections.
  8. Check the App/Software:If you’re using an app to control the camera hub, ensure that the app is up to date. Try closing and reopening the app.
I was having a similar issue when I got mine. It was mounted over garage and my router was about maybe 30 feet away. I found when I changed the channel of 5g on my router it improved greatly. And just a FYI… I have terabyte hi speed internet and a Smart home with about 85 connections.
From 2.4 g about. 50 , 5g about 20 and remaining hard Ethernet.
