Failed to connect the sensor device (4th step, Failed to send the network configuration information)
I’m trying to connect the Aqara Presence Sensor FP2 with the Wi-Fi using Aqara Home app but it always failed to connect to the Wi-fi. On my first try, it connected and can also detect human presence. After few days later, I am trying to connect again but every time it failed to connect.
Error : “Failed to send the network configuration information. Error code 10004”
Here the things I have tried:
  1. I have checked the network is 2.4. GHz band.
  2. The sensor is in ready-to-connect state.
  3. Reinstall the Aqara Home app and try to connect.
  4. Clear the Aqara Home app cache and reset the sensor’s settings.
  5. Try different network with 2.4 GHz band.
  6. Try different account in Aqara Home app.
  7. Reset the settings (Pressing power button 10 times)
  8. Tried with different phone (Android).
But nothing works. Your help is appreciated. Thanks.
Hey!
Try this :
1.Turn off mobile data.
2.Connect to the Wi-Fi network you are going to connect the device to (This network must have Internet connection).
3.Restart your phone.
4.Unplug the Aqara device, wait for 2 minutes and plug it again.
5.Open the Aqara app and attempt to add it.
Thanks for your suggestions. There was a bug on the Aqara Home app. I got an update on the app and now it works fine.
I have the same issue. Error 10004 while I try to setup using Android. Wasted all day with no way to connect the sensor. I’ll return it.
@j_smarthome Hey @j_smarthome, totally feel your frustration here—Error 10004 on the FP2 is one of those annoying roadblocks that can eat up a whole day. Since you’ve already tried the standard troubleshooting dance, here are a few extra angles that have worked for some users in similar situations:
  • Turn off mobile data on your Android phone during setup—sometimes the phone tries to route through cellular instead of Wi-Fi.
  • Restart your phone fresh before attempting pairing again.
  • Power cycle the FP2: unplug it for a full 2 minutes, then plug back in before retrying.
Also worth double-checking: if you’re on a dual-band router, try disabling Wi-Fi 7 compatibility or temporarily separating the 2.4GHz and 5GHz bands with different SSIDs—some Android devices get finicky about this.
If none of these do the trick, since you’ve already exhausted quite a bit, reaching out directly would be your best next step. Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, click here to create a ticket.
Hope you get it sorted—would hate to see a good sensor go back over a connectivity hiccup
