** Feature Request ** Matter Bindings and Decouple Relay
Hi,
I need Matter bindings for my Aqara T2 bulbs and my Aqara H2 EU light switches in Matter over Thread mode.
I also need to decouple the relay from the light switch, because I use Aqara T2 smart bulbs only.
Any idea, when we will see these features?
Thanks and regards Hoppel
Matter Binding would be great! Not seeing a lot of manufacturers doing that yet, but it would be a welcomed feature!
I’m in the US so don’t have the EU version of the switch, but you should be able to decouple the relay from the switch in the Aqara app settings. Is this not the case? For the US version of the switch the parallel is Settings > Switch Settings > Switch Settings. Hopefully there is a parallel on your version.
I do not have an Aqara Hub, but I have 7 Apple Thread Border Routers / Home Hubs. At the moment I use my light switches via Zigbee2MQTT and my bulbs via Matter over Thread in Home Assistant, because some month ago it was not possible to configure the decouple mode on an Aqara H2 EU light switch, when it was in Thread mode.
With Home Assistant we are now able to configure Matter bindings. But without being able to configure the decouple mode via Home Assistant, I can’t check the binding functionality.
How are you using your light switch (Thread or Zigbee)? Do you have an Aqara Hub?
According to the Matter compliance document here there is no support for binding to lights.
There’s no Binding cluster but since that could be missing in the document, the ultimate proof is that there’s no On-Off cluster support as client, which would be required to bind to the On-Off server of the light.
Checking the documents is not fail-proof though, sometimes there’s no document for the latest versions and sometimes vendors use Fast-Track for recertifications and the document belongs to another device which might not have the exact same features.
Sure?
On the Home Assistant discord I found a guy, who successfully bound an Inovelli White dimmer with an Aqara T2 bulb:
He also added a second binding for the dimming cluster to the same switch so now both on/off and dimming are controlled on the T2. dims quickly and smoothly:
Some posts later he wrote, that on/off/dim also works with a Nanoleaf essentials NL67 bound to the same inovelli switch:
There were some issues with deleting the bindings/acls. But with the latest official Home Assistant Matter Server this issue should be solved
matter alpha also reported about the binding feature while in beta phase:
What do you think about it?
You were asking about the Aqara H2, not the Inovelli which wasn’t even mentioned. My answer is about the Aqara H2.
Yeah, ok, now I understand you. Sorry, English is not my native language. :wink:
So my feature request is absolutely valid, we need the Matter binding cluster and the decoupling functionality for the Aqara H2 EU/US light switch and other comparable Aqara light switches.
It’s a valid request indeed, I’d also like to have wireless dimmers (battery powered buttons) or even sensors with binding capabilities to control lights independently of hubs or automations.
Fortunately, lights don’t need support for bindings, every Matter light would work. Explicit binding to lights support is only needed in the device that controls the light, be it a switch, button, sensor, etc. since it has to send the specific commands a light expects like on, off, etc.
I didn’t know that, thank you for clarifying.
So, now we need the Aqara guys to give us these two features.
@AqaraBot When do we get the Matter Features to decouple a a relay from and to bind smart lights to a Matter over Thread H2 light switch?
@hoppel118 Hey Hoppel! I’m sorry, but there’s no information in our reference content about when you’ll get the Matter features to decouple the relay and bind smart lights to a Matter over Thread H2 light switch.
Our community is a great place for collaboration. Maybe others here have some insights or experiences to share that could help. And if you have any suggestions or improvements you’d like to see, you can submit manual customer service feedback. This helps us drive improvements to our products and services.
Let’s keep an eye on the forum and hope we can find a solution or get some updates on this soon!
Are there still no pans to support Matter Bindings by Aqara?
Especially for Light Switches it would be very crutial to ensure the light is still working when your smart matter device/controller has issues.
And also it would reduce latency.
@m_hollerweger You seem to be inquiring about Aqara’s plans to support Matter Bindings for light switches. Currently, there is no relevant information available in the reference content regarding this feature. For the latest updates on product features and plans, you can contact customer support for assistance.
Seems that Inovelli supports bindings with their light switches: Matter Thread On/Off Switch VTM30-SN - Matter Survey
Hope Aqara will support this soon.
Hi, any news on this front? I have the H2 rotary dimmer switches and Aqara E27 RGBW bulbs. Would love to bind them directly via my Home Assistant Matter Server.
Any update on Matter Binding and decoupled relays for Thread? I have some rooms that need that, and considering buying Innovelli switches instead
+1 for decoupling
