Feature request: Support for 3-stage A/C & heat pumps (Y3)
Right now, no mainstream smart thermostat (Nest, Ecobee) supports true 3-stage cooling or heat pumps (Y3). Anyone running higher-end multi-stage equipment is pretty much forced to buy locked-down, crappy thermostats from Carrier, Trane, etc.
Could we get this added via a firmware update on the current W200? For instance, allowing us to assign an unused terminal like W2 into a Y3 stage? If the hardware doesn’t allow it, definitely consider building it into whatever successor model comes next.
Adding 3-stage support would instantly make the Aqara thermostat the go-to recommendation for people with high-end HVAC setups, and would be a massive differentiator for Aqara.
@militia-mover_2m Thanks for the detailed feature request — it’s clear you’ve put real thought into where the W200 could stand out in the market.
Right now, the W200 supports up to 2-stage heating and 2-stage cooling for furnaces and ACs, and 2-stage heating plus 2-stage auxiliary heating for heat pumps. So a true third stage (Y3) isn’t on the current hardware roadmap, and I can’t speak to whether a firmware re-map of terminals like W2→Y3 would be electrically feasible — that would need validation from the hardware team.
Your broader point about the gap in mainstream smart thermostats for high-end multi-stage equipment is well taken, though. It’s exactly the kind of use-case feedback that helps shape future product direction.
For this kind of hardware capability request and to get it in front of the right folks, the best path is through official channels rather than the forum thread. Contact the Aqara Home App Customer Service Team (Profile> Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket.
Appreciate you laying out the competitive angle so clearly — hope the team takes a close look at this one.
