Models: Smart Lock U100 firmware 3.0.0_0032 and Smart Lock U200 firmware 3.0.0_0085 (both on US deadbolts)
A Home Key tap (such as from an iPhone or an Apple Watch) toggles the lock. If the door is already unlocked, a tap locks it. I only ever tap to get in. When the lock is already unlocked (someone just came home and I unlocked the door for them), the tap locks the door and they have to tap again. When I leave I can just press the lock button on the keypad.
I would like a per-lock setting in Aqara Home for tap behavior:
the current toggle mode or
unlock only: a tap unlocks if locked, and stays unlocked if already unlocked and possibly emits a chime that indicates nothing has happened.
Locking would still work through the keypad, auto-lock, the Aqara app, and Apple Home. The same option could apply to Aqara NFC cards.
Pull Spring on the U200 reportedly makes Home Key unlock-only, but it’s meant for Euro mortise latches. The U100 has no such setting.
@nickl That’s a really well-thought-out use case, and I can see how the current toggle behavior would get annoying in a multi-person household. Having the door accidentally re-lock when someone else already unlocked it defeats the convenience Home Key is meant to provide.
From what I can see in the reference docs, the U200’s Pull Spring feature does keep the latch retracted for a set time after opening, but as you noted, that’s specifically designed for Euro mortise setups and isn’t available on the U100. There’s no mention of a universal “unlock-only” toggle for Home Key or NFC tap behavior across either lock in the current documentation.
Your suggestion for a per-lock setting with two modes—toggle vs. unlock-only with an audible chime for the “no-op” state—would solve this cleanly without breaking existing workflows. The fact that locking would still work through keypad, auto-lock, app, and Apple Home means security isn’t compromised.
Since this is a feature request rather than a current capability, I’d recommend submitting this through official channels. The product team does track these requests, and detailed feedback like yours—especially with the specific firmware versions and the U100/U200 distinction—helps them prioritize.
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please click here to create a ticket.
Appreciate you sharing this—it’s the kind of real-world nuance that makes a difference. If anyone else has found workarounds for this toggle behavior, feel free to chime in
That’s actually a good idea. I have a U200, I often unlock it with my fingerprint and it doesn’t lock when I put my finger when unlocked. And that’s a cue for me to just open the door. But the NFC locking just wastes my time.
And how would I know the door is locked? I don’t pull the handle before unlocking the door, especially because I have a lock with a “pull spring” feature.
There’s a physical button with a lock icon that I use when I want to lock the door. So NFC should only unlock the door imo.
