I wanted to share my experience with the Fibaro Dimmer 2 after struggling with brightness calibration. My setup includes a Fibaro Dimmer 2 paired with Fibaro Bypass 2 and three Airam 5.4W LED spots. Initially, I was puzzled when the brightness level maxed out at 53%, even after calibration. Moving the dimmer to 99% just brought it back to 53%, which was frustrating since the lights seemed as bright as they could get.After some research and trial and error, I discovered that adjusting the calibration settings in the Fibaro Home Center app made a significant difference. By tweaking the ‘Calibration’ and ‘Max Level’ parameters under the device settings, I was able to achieve a smoother brightness curve. It’s a bit of a process, but the results are worth it!For anyone else facing similar issues, I recommend experimenting with these settings. Also, if you’re using LED spots, make sure they’re compatible with your dimmer to avoid flickering or unexpected behavior. It’s all about finding the right balance between hardware and software settings. Happy automating! ![]()
