Hello everyone, I wanted to share my recent experience integrating the Fibaro Dimmer 2 into my smart home setup. After some trial and error, I managed to create a seamless automation system that I’d like to walk through with you all.
Initially, I was aiming to use the second switch (S2) on the Fibaro Dimmer 2 to control my smart bulbs. However, I encountered an issue where the S2 switch stopped working, and the preconditions in my routines were empty. After some research and reaching out to the community, I found that this was a known issue with the Fibaro firmware. Updating the firmware resolved the problem, and now the S2 switch functions perfectly alongside the first switch.
For those interested in automating their lighting system, here’s a tip: I’ve set up a scene where the lights dim gradually in the evening based on sunset times. This creates a cozy ambiance without manual intervention. I’ve also integrated motion sensors to ensure the lights only come on when needed, which has significantly reduced energy consumption.
Another thing I’d like to mention is the importance of firmware updates. I’ve learned to regularly check for updates for all my devices, not just the Fibaro Dimmer 2. A recent firmware update for my HMIP thermostats, for instance, fixed an issue where they wouldn’t return to the AUTO mode after a restart. It’s a small detail, but it makes a big difference in maintaining a smooth system operation.
If anyone is looking to integrate multiple brands or devices, I highly recommend using a robust automation platform like Luup or OpenHAB. These tools allow for extensive customization and have a strong community support system. I’ve even managed to create a simple script that automates my morning routine—turning on the lights, adjusting the thermostat, and brewing coffee—all with the press of a button.
I’d love to hear about your experiences and any tips you might have for optimizing smart home setups. Let’s keep the knowledge sharing going! ![]()
