Fibaro Dimmer 2 Randomly Turning On/Off - Seeking Solutions
Hello everyone, I’ve recently installed a Fibaro Dimmer 2 in my basement to control the lighting. While it works perfectly with my IKEA motion sensor for the most part, I’ve encountered a peculiar issue: the dimmer randomly turns on and off, seemingly without any trigger. This is quite frustrating, especially since the other smart lights in the basement remain unaffected.
I initially thought it might be a software glitch, so I disconnected it from the motion sensor flow to isolate the problem. However, the issue persists, with the dimmer switching states every 30 seconds or so. Interestingly, I can see these changes reflected in the Homey app, which suggests it’s not a false reading but an actual state change.
I’ve tried resetting the device and ensuring all firmware is up to date, but nothing seems to resolve the issue. I’m curious if anyone else has experienced this with the Fibaro Dimmer 2 and if there are known solutions or workarounds. Any advice or insights would be greatly appreciated! Thanks in advance for your help.
