Fibaro Double Switch 2: A Comprehensive Experience
I recently upgraded my home automation setup with the Fibaro Double Switch 2, and I wanted to share my experience and insights with the community. After researching several options, I decided on the Fibaro Double Switch 2 due to its versatility and compatibility with my existing Z-Wave network. However, I encountered a few challenges along the way that I thought others might find helpful to know about.
Initially, I was unsure about which device handler to use for the Fibaro Double Switch 2. I explored both the Fibaro Double Switch 2 – USB and the Fibaro Double Switch 2 ZW5 options. After some experimentation, I found that the Fibaro Double Switch 2 ZW5 handler provided better integration with my system, especially when paired with other Z-Wave devices. I also compared it with the erocm123 handler for the Fibaro Double Switch 2 FGS-223 and noticed that the ZW5 handler offered more consistent performance in terms of reliability and response time.
One of the features I most appreciate about the Fibaro Double Switch 2 is its ability to handle multiple scenarios seamlessly. For instance, I’ve set up one switch to control my living room lights and the other to manage my outdoor floodlights. The integration with Google Assistant has been a game-changer, allowing me to voice-control my lights effortlessly. I’ve also created some simple routines, like turning on the floodlights when motion is detected at night, which has significantly enhanced my home security.
However, I did run into a minor issue with the wake-up configuration value in HABmin. After updating the value, I noticed that it reverted to the default setting upon rebooting my openHAB system. This was a bit frustrating, but I managed to resolve it by ensuring that the wake-up interval was correctly configured in the device settings. I also found that manually requesting an update after making changes helped maintain the correct settings.
Overall, the Fibaro Double Switch 2 has been a fantastic addition to my smart home setup. Its reliability, ease of use, and compatibility with a wide range of devices make it a standout product. I’d highly recommend it to anyone looking to enhance their home automation system. If you have any questions or need assistance with similar setups, feel free to reach out—I’d be happy to help!
