Fibaro FIBEFGS-223 Energy Meter Issue: Troubleshooting and Solutions
Hey everyone, I wanted to share my experience with the Fibaro FIBEFGS-223 module, specifically regarding an issue I encountered with the energy meter updates. I hope this can help others who might be facing the same problem or provide some insights into potential solutions.
So, I recently set up the Fibaro Double Switch module in my smart home setup. It’s been a great addition, allowing me to control two separate devices from a single switch. However, I noticed something odd with the energy consumption readings. While the total wattage was updating correctly, the individual port readings weren’t reflecting the actual power usage. For instance, if port 1 was drawing 15.7 watts, it would show correctly, but when I turned off the device, only the total wattage would update to zero, leaving the individual port reading unchanged. This inconsistency was a bit puzzling and a bit frustrating, as accurate energy monitoring is crucial for my home automation setup.
After some research and reaching out to the community, I discovered that this issue isn’t unique to my setup. It seems to be a known bug with the module, particularly when it comes to updating individual port readings. While the exact cause isn’t clear, it appears to be related to how the module communicates energy data to the hub. Fortunately, there are a few workarounds that can help mitigate this issue:
  1. Manual Refresh: One simple solution is to manually refresh the energy readings in your smart home app. While this isn’t a permanent fix, it can provide you with accurate data on demand.
  2. Firmware Updates: Keeping your module’s firmware up to date is always a good practice. Sometimes, these bugs are addressed in newer firmware versions, so it’s worth checking for updates regularly.
  3. Alternative Metering Solutions: If the issue persists and accurate individual port readings are essential for your setup, consider integrating additional energy meters. This might involve using separate sensors for each device or exploring other compatible modules that offer more reliable metering capabilities.
  4. Community Support: Don’t hesitate to reach out to forums and communities like this one. Often, other users have encountered similar issues and may have valuable insights or solutions to share.
On a positive note, Fibaro has been responsive to user feedback in the past, and I’m hopeful that a fix for this issue will be rolled out in future updates. In the meantime, the workarounds mentioned above can help keep your energy monitoring functional.
I’d love to hear from others who might have experienced this issue or have additional solutions to share. Let’s keep the conversation going and help each other troubleshoot these kinds of challenges!
Cheers,
