Fibaro Home Center 2 Data Parsing Experience
Hello everyone,
I recently started working with the Fibaro Home Center 2 and have been exploring its capabilities for integrating various sensors into my smart home setup. One of the challenges I encountered was parsing data from an HTTP request. I thought I’d share my experience and the solution I found, in case it helps anyone else.
The Challenge
I was trying to fetch weather data from an external source using Lua scripting. The data was returned in a plain text format with key-value pairs, something like this:
Rain: 0.3
UV: 1.23
Wind: 23.0
WindVane: S
Temperature: 23.3
My goal was to extract each value into separate variables for further processing. At first, I wasn’t sure how to approach this, as I’m still learning Lua and its string manipulation capabilities.
The Solution
After some research and asking around the community, I discovered that using Lua’s string.gsub function with a pattern was the way to go. Here’s a simplified version of what I did:
lua
local response = “Rain: 0.3\nUV: 1.23\nWind: 23.0\nWindVane: S\nTemperature: 23.3”
local rain, uv, wind, windVane, temperature = nil, nil, nil, nil, nil
response:gsub(“([%w]+):%s*(.-)”, function(key, value)
if key == “Rain” then
rain = tonumber(value)
elseif key == “UV” then
uv = tonumber(value)
elseif key == “Wind” then
wind = tonumber(value)
elseif key == “WindVane” then
windVane = value
elseif key == “Temperature” then
temperature = tonumber(value)
end
end)
print("Rain: " … rain)
print("UV: " … uv)
print("Wind: " … wind)
print("WindVane: " … windVane)
print("Temperature: " … temperature)
This script iterates over each line of the response, captures the key-value pairs, and assigns them to variables. It’s a neat way to handle such data parsing without getting too bogged down in complex string operations.
What I Learned
  1. Community Support: The Lua and Fibaro communities are incredibly helpful. If you’re stuck, don’t hesitate to ask for advice. Someone out there has likely faced the same challenge.
  2. Pattern Matching: Lua’s gsub function with patterns is a powerful tool for parsing structured text. It’s worth investing time to understand how it works.
  3. Data Handling: Always validate and convert your data appropriately. In this case, converting string values to numbers was essential for further calculations.
This experience reinforced my belief in the power of scripting within smart home systems. While it can be challenging at times, the flexibility and control it offers are well worth the effort. I’m excited to continue exploring what the Fibaro Home Center 2 can do and look forward to sharing more insights as I progress.
Thanks to everyone who contributed to solving this puzzle! Happy scripting!
Best regards,
