Hello everyone, I wanted to share my experience with the Fibaro Motion Sensor and some tips I’ve picked up while setting up my smart home. I’ve been using the Fibaro Motion Sensors for a while now, and while they have their quirks, they’re a great addition to any smart home setup.
First, let me talk about the motion detection. The Fibaro Motion Sensors have a 90-degree detection angle, which is perfect for covering doorways or specific areas without overlapping too much. However, I noticed that sometimes the sensors don’t trigger as quickly as I’d like, especially in darker environments. I’ve found that adjusting the sensitivity settings in the app helps a lot. If you’re experiencing delays, I’d recommend tweaking these settings to find the right balance between responsiveness and false triggers.
Another thing I wanted to mention is how I integrated these sensors into my daily routines. I use them primarily for lighting automation—turning on lights when I enter a room and turning them off after a period of inactivity. To prevent the lights from turning off while I’m still in the room, I set the delay to 10 minutes. It’s a simple setup, but it makes a big difference in convenience.
For those looking to integrate multiple brands or devices, I’ve found that using a hub like SmartThings or Hubitat makes the process much smoother. These hubs allow you to create custom rules and automations that work seamlessly across different devices. For example, I have a rule where my lights adjust based on the time of day and motion detection, creating a more dynamic and energy-efficient setup.
I’d also like to share a tip for anyone struggling with device connectivity. Sometimes, devices can drop off the network, especially during power outages or router reboots. To mitigate this, I’ve started using a simple script that pings my devices periodically and sends me a notification if something goes offline. It’s a small tweak, but it’s saved me a lot of frustration.
Lastly, I want to encourage anyone who’s just starting out with smart home automation not to be afraid of experimenting. The learning curve can be steep, but the payoff is well worth it. Whether you’re setting up a basic lighting system or creating complex automations, every step you take brings you closer to a home that truly feels like your own.
If anyone has questions or tips of their own, I’d love to hear them! Happy automating! ![]()
