Earlier this year, I decided to enhance my smart home setup by purchasing two Fibaro Smart Implants. I was pleasantly surprised when they arrived as FGBS-222 models, priced at a very reasonable 70 EUR each, which was a great find compared to their usual price tag. These devices promised to add versatility to my system, supporting both binary sensors and voltage sensors, along with temperature monitoring. However, the journey to fully integrate them into my Vera system wasn’t without its challenges.
Initially, I faced confusion with the device’s endpoint design. Vera created all child devices regardless of the actual configuration, which led to some unnecessary sensors being active. After some research and trial and error, I discovered that hiding the unused analog sensors was the key to a cleaner setup. This process required setting specific parameters in the device configuration to ensure only the binary inputs were active.
One of the trickiest parts was understanding how to map the ZWave commands properly. By adjusting the ‘BasicSetCapabilities’ variable in the device settings, I was able to ensure that each input channel reported correctly without overlapping. This involved some detailed parameter tweaking, but the result was worth it—my binary sensors now function seamlessly within Vera.
I also found that disabling polling on the main device improved performance, as the FGBS-222 sends updates instantaneously when changes occur. This adjustment made the system more efficient and responsive.
Overall, while the setup required some manual intervention and a bit of troubleshooting, the Fibaro Smart Implants have proven to be a valuable addition to my smart home ecosystem. Their reliability and the ability to customize their functionality have made my home more connected and efficient. I’m excited to continue exploring their capabilities and look forward to sharing more insights as I delve deeper into their features.
If anyone else is working with these devices or similar setups, I’d love to hear about your experiences and any tips you might have!
