I’m working on setting up a flow using my Fibaro Smart Implants to control my home’s ventilation system. I have two implants that I want to use to switch the ventilation to different modes. Specifically, I want Output 1 to set the ventilation to normal mode and Output 2 to set it to maximum mode. However, I’m running into some issues with the flow configuration.
Currently, I’m trying to create a flow where the system checks the status of Output 1 and Output 2 and adjusts the ventilation accordingly. Unfortunately, I can’t seem to find an option in the flow editor that allows me to monitor the output states directly. I’ve tried using the input states as a workaround, but it doesn’t quite work as intended.
Has anyone successfully configured a similar setup? I’m curious if there’s a way to directly reference the output states in a flow or if there’s a different approach altogether. Any advice or suggestions would be greatly appreciated! I’m really looking forward to getting this working smoothly to optimize my home’s ventilation system.
