Fibaro Vertical Slider Setup and Customization Tips
Hey everyone, I’ve been absolutely loving my Fibaro blind control setup, especially the FGR-222 model. It’s been working seamlessly with the Fibaro-dimmer standard code, and I’m really impressed with how smooth everything runs. However, I’ve been wanting to tweak one small thing to make it even more intuitive for my daily use—changing the slider orientation from horizontal to vertical. I thought I’d share my journey and any tips I’ve picked up along the way in case anyone else is looking to do the same!
The Setup and Initial Thoughts
I’ve got my Fibaro blinds integrated into my smart home ecosystem, and while the horizontal slider works perfectly, I find myself reaching for the vertical option more naturally. It just feels more intuitive for how I interact with my devices, especially on smaller screens. I knew it was a minor tweak, but I wanted to make sure I did it right without messing up any of the existing functionality.
The Process
After some quick research, I found that adjusting the slider orientation isn’t too complicated, but it does require a bit of trial and error. I started by exploring the device settings within my smart home platform. I was pleasantly surprised to find that there was an option to customize the slider orientation, but it wasn’t immediately obvious where it was hidden. After digging through the menus, I finally located the setting and gave it a try.
Testing and Fine-Tuning
Once I switched the slider to vertical, I wanted to make sure everything still worked as expected. I tested opening and closing the blinds multiple times, and I was happy to see that the functionality remained unchanged—it was just the visual aspect that had been altered. However, I did notice that the transition felt a bit off at first. It took a little getting used to, but after a day or two, it felt completely natural.
Tips for Others
If you’re looking to make a similar change, here are a few tips I’d recommend:
  • Backup Your Current Settings: Before making any changes, take a moment to backup your current setup. It’s a simple precaution that can save you a lot of hassle if something doesn’t go as planned.
  • Test in a Safe Environment: If possible, test your changes in a controlled environment where you can easily revert if needed. This way, you can experiment without affecting your daily routine.
  • Give Yourself Time to Adjust: Even though the change is minor, it might take a little time to get used to the new layout. Be patient and let your brain adapt to the new visual cue.
Switching the slider orientation was a small but meaningful improvement for me. It’s a great reminder that even the smallest tweaks can make a big difference in how we interact with our smart home devices. I’m really happy with how everything turned out, and I’m already brainstorming other ways to customize my setup even further.
If anyone else has tips or tricks for optimizing their Fibaro setup, I’d love to hear them! Let’s keep the ideas flowing!
Best regards,
